Deleting IP Address Entries from an IP Address Group
This section describes how to delete IP address entries from an IP address group.
If an IP address group has resources associated, deleting IP address entries from the group may affect your network communications.
If an IP address group has security groups and network ACLs associated, the rules associated with the IP address group will change.
- Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose IP Address Groups.
The IP address group list is displayed.
- In the IP address group list, click the name of the target IP address group.
The basic information page of the IP address group is displayed.
- Delete IP address entries:
- Delete a single IP address entry.
- In the IP address entry list, locate the target IP address entry and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
- Delete IP address entries in batches.
- In the IP address entry list, select the IP address entries to be deleted.
- Click the Delete button above the IP address entry list.
