Updated on 2026-01-06 GMT+08:00
Adding IP Address Entries to an IP Address Group
This section describes how to add IP address entries to an IP address group.
If an IP address group has resources associated, adding IP address entries to the group may affect your network communications.
If an IP address group has security groups and network ACLs associated, the rules associated with the IP address group will change.
  1. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  2. In the navigation pane on the left, choose IP Address Groups.
    The IP address group list is displayed.
  3. In the IP address group list, click the name of the target IP address group.
    The basic information page of the IP address group is displayed.
  4. In the left corner above the IP address entry list, click Add.
    The dialog box for adding IP address entries is displayed.
  5. Add IP address entries to the IP address group as prompted.
    • Method 1
      1. Enter IP address entries in the IP Address Entries box. For details, see Table 1.
        Table 1 Parameters for adding IP addresses
        Example Value
        Name
        The name of the IP address group.
        ipGroup-A
        Max. Entries
        Mandatory
        Set the number of IP address entries that can be added to an IP address group. By default, the system displays the maximum number of IP address entries that can be added to an IP address group. You can change the number as required.
        20
        IP Address Version
        IP address version supported by an IP address group. You can select an IP address version when you create an IP address group. IP address version cannot be modified after the IP address group is created. The supported versions are as follows:
        • IPv4
        • IPv6
        IPv4
        IP Address Entries
        Mandatory
        Enter an IP address or IP address range on each line, and press Enter.
        The format is "IP address | Description". Description is optional, can contain 0 to 255 characters, and cannot contain angle brackets (< or >). You can enter:
        • An IPv4 address range, for example, 192.168.0.0/16 or 192.168.0.0/16 | ECS01
        • A single IPv4 address, for example, 192.168.10.10 or 192.168.10.10 | ECS01
        • An IPv6 address range, for example, 2001:db8:a583:6e::/64 or 2001:db8:a583:6e::/64 | ECS01
        • A single IPv6 address, for example, 2001:db8:a583:6e::5c or 2001:db8:a583:6e::5c | ECS01
        • Without description: 192.168.0.0/16
        • With description: 192.168.0.0/16 | ECS01
      2. Click OK.
        In the IP address entry list, you can view the newly added IP address entries.
    • Method 2
      Click Batch Import in the lower part of the IP Address Entries box. On the displayed dialog box for batch adding IP address entries, import IP address entries by referring to Importing IP Address Entries to an IP Address Group in Batches.
