Help Center/ Virtual Private Cloud/ User Guide (Ally Region)/ IP Address Group/ Managing an IP Address Group/ Disassociating an IP Address Group from a Security Group or Network ACL
Updated on 2026-11-17 GMT+08:00
This section describes how to disassociate an IP address group from a resource.
An IP address group can be associated with security groups and network ACLs.
  • In a security group, you can modify or delete the rules with source or destination set to an IP address group.
  • In a network ACL, you can modify or delete the rules with source or destination set to an IP address group.
Disassociating an IP address group will make the corresponding rules invalid, and this action cannot be undone.
  1. Click in the upper left corner and select the project.
  2. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  3. In the navigation pane on the left, choose IP Address Groups.
    The IP address group list is displayed.
  4. In the IP address group list, locate the target IP address group and click the resource name in the Associated Resources column.
    The Associated Resources page is displayed.
  5. In the Associated Resources list, click the corresponding resource name.
    The resource summary page is displayed. You can refer to Table 1 to disassociate the IP address group from resources.
    Table 1 Disassociating an IP address group from resources
    Resource
    Reference
    Security group
    Modify or delete inbound or outbound rules associated with the IP address group.
    network ACL
