IP Address Group Overview
What Is an IP Address Group?
An IP address group is a collection of IP addresses. It can be associated with security groups and network ACLs to simplify IP address configuration and management.
| Associated Resource | Description | Example |
| Security group | The Source or Destination of a security group rule can be set to IP address group. | As shown in Figure 1, the inbound rule of security group sg-A uses IP address group ipGroup-A as the source. |
| Network ACL | The Source or Destination of a network ACL is set to IP address group. | As shown in Figure 1, the inbound rule of network ACL fw-A uses IP address group ipGroup-A as the source. |
IP Address Group Use Cases
- Unified management of whitelisted IP addresses for Internet access: If multiple cloud servers need to allow access from the same public IP addresses, configuring security group rules individually is labor-intensive and hard to maintain. You can use an IP address group to centrally manage these public IP addresses and reference the IP address group in security group rules. If any of the public IP addresses changes, you only need to modify the IP address group. The changes will automatically take effect for all associated security group rules.
- Maintaining IP address ranges for communication in batches: If multiple security groups or network ACLs need to allow traffic from the same IP address ranges, adding them individually is repetitive and increases the risk of omissions during future updates. You can add the IP address ranges to an IP address group for unified management. Security group and network ACL rules can directly reference the IP address group. If you modify the IP address group, the changes automatically take effect for all associated rules, reducing O&M costs.
- If a network ACL rule uses an IP address group:
- Either the source or the destination of an inbound rule can use the IP address group.
- Either the source or the destination of an outbound rule can use the IP address group.
For example, if the source of an inbound rule in a network ACL is set to an IP address group, the rule destination can only be an IP address.
