Creating an IAM User and Granting DMS for Kafka Permissions
This section describes how to use Identity and Access Management (IAM) for fine-grained permissions control for your Distributed Message Service (DMS) for Kafka resources. With IAM, you can:
- Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing DMS for Kafka resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust another account or cloud service to perform efficient O&M on your DMS for Kafka resources.
If your account meets your permissions requirements, you can skip this section.
This section describes the procedure for granting user permissions. Figure 1 shows the process flow.
Learn about the permissions (see System-defined roles and policies supported by DMS for Kafka) supported by DMS for Kafka and choose policies according to your requirements. For the permissions of other services, see System Permissions.
DMS for Kafka permissions policies are based on DMS. Therefore, when assigning permissions for user groups, select DMS permissions policies.
Process Flow
For the following example, create a user group on the IAM console and assign the DMS ViewerAccess policy to the group.
- Log in as the IAM user and verify permissions.
In the authorized region, perform the following operations:
- Choose Service List > Distributed Message Service for Kafka. Then click Buy Instance on the console of DMS for Kafka. If a message appears indicating that you cannot perform the operation, the DMS ViewerAccess policy is in effect.
- Choose Service List > Elastic Volume Service. If a message appears indicating that you have insufficient permissions, the DMS ViewerAccess policy is in effect.
- Choose Service List > Distributed Message Service for Kafka. If the Kafka instance list can be displayed, the DMS ViewerAccess policy is in effect.
Example Custom Policies
You can create custom policies to supplement the system-defined policies of DMS for Kafka. For details about actions supported in custom policies, see Permissions and Supported Actions.
To create a custom policy, choose either visual editor or JSON.
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a JSON policy or edit an existing one.
For details, see "Creating a Custom Policy" in the Identity and Access Management User Guide. The following lists examples of common DMS for Kafka custom policies.
- Example 1: Grant permission to delete and restart instances.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "dms:instance:modifyStatus", "dms:instance:delete" ] } ] } - Example 2: Grant permission to deny instance deletion.
A policy with only "Deny" permissions must be used together with other policies. If the permissions granted to an IAM user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
For example, if you want to assign all of the permissions of the DMS AdminAccess policy to a user, except for deleting instances, you can create a custom policy to deny only instance deletion. When you apply both the DMS AdminAccess policy and the custom policy denying instance deletion, since "Deny" always takes precedence over "Allow", the "Deny" will be applied for that one conflicting permission. The user will then be able to perform all operations on instances except deleting instances. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "dms:instance:delete" ] } ] }
DMS for Kafka Resources
A resource is an object that exists within a service. DMS for Kafka resources include kafka. To select these resources, specify their paths.
| Resource | Resource Name | Path |
| kafka | Instance | [Format] DMS:*:*: kafka:instance ID [Notes] For instance resources, IAM automatically generates the prefix (DMS:*:*:kafka:) of the resource path. For the path of a specific resource, add the instance ID to the end. You can also use an asterisk * to indicate any resource. For example: DMS:*:*:kafka:* indicates any Kafka instance. |
DMS for Kafka Request Conditions
Request conditions are useful in determining when a custom policy is in effect. A request condition consists of condition keys and operators. Condition keys are either global or service-level and are used in the Condition element of a policy statement. Global condition keys (starting with g:) are available for operations of all services, while service-specific condition keys (starting with a service name such as dms:) are available only for operations of specific services. An operator must be used together with a condition key to form a complete condition statement.
DMS for Kafka has a group of predefined condition keys that can be used in IAM. For example, to define an "Allow" permission, use the condition dms:ssl to filter instances by SASL configurations. The following table lists the DMS for Kafka predefined condition keys.
| Condition Key | Operator | Description |
| dms:publicIP | Bool | Whether public access is enabled |
| dms:ssl | Bool | Whether SSL is enabled |
