Changing RocketMQ Message Retention Period
Message retention period is a period that messages in a topic are retained for. Consumers must retrieve messages before this period ends. Otherwise, the messages will be deleted and can no longer be retrieved.
The retention period of normal messages and dead letter messages is controlled by and changes with the message retention period.
After creating an instance, you can modify its message retention period based on service requirements. Changing the retention period does not restart the instance. The default message retention period is 48 hours.
Prerequisite
A RocketMQ instance has been purchased.
- Log in to the console.
- Click
in the upper left corner to select a region. DMS instances in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the DMS for RocketMQ page. - Click a RocketMQ instance name to go to the instance overview page.
- Click
next to Message Retention. Enter an integer in the range from 1 to 720.
- Click
. The modification result is displayed in the upper right corner of the page.
