Updated on 2026-01-26 GMT+08:00
MMDD
Application Scenarios
This algorithm applies when you want to shard data by day in a year. One table shard for one day is recommended. So table shards in each database shard cannot exceed 366 because there are at most 366 days in a year.
Instructions
  • The sharding key must be DATE, DATETIME, or TIMESTAMP.
  • This algorithm can be used only for table sharding. It cannot be used for database sharding.
Data Routing
Use the day number of a year in the sharding key value to find the remainder. This remainder determines which table shard your data is routed to and serves as the name suffix of each table shard.
For example, if the sharding key value is 2019-01-15, the calculation of the table shard is: Day number in a year mod Table shards, that is, 15 mod 366 = 15.
Calculation Method
Table 1 Required calculation methods
Condition
Calculation Method
Example
None
Table routing result = Table sharding key value % Table shards
Sharding key value: 2019-01-15
Table shard: 15 % 366= 15
Syntax for Creating Tables
create table test_mmdd_tb (
    id int,
    name varchar(30) DEFAULT NULL,
    create_time datetime DEFAULT NULL,
    primary key(id)
) ENGINE=InnoDB DEFAULT CHARSET=utf8
dbpartition by MOD_HASH(name)
tbpartition by MMDD(create_time) tbpartitions 366;
Precautions
Table shards in each database shard cannot exceed 366 because there are at most 366 days in a year.
