Help Center/ Distributed Database Middleware/ User Guide (Ally Region)/ Parameter Template Management/ Comparing Two Parameter Templates
Updated on 2026-01-26 GMT+08:00
You can apply different parameter templates to the same DDM instance to view impacts on parameter settings of the instance.
- Log in to the DDM console.
- Choose Parameter Templates, click the Custom Templates tab, locate the required parameter template, and click Compare in the Operation column.
You can also click the Default Templates tab and compare a default template with a custom template.
- In the displayed dialog box, select a parameter template and click OK.
- If their settings are different, the parameter names and values of both parameter templates are displayed.
- If their settings are the same, no data is displayed.
Parent topic: Parameter Template Management
