Help Center/ CodeArts Build/ User Guide (Ally Region)/ User Guide/ Configuring Build Actions/ Configuring Build Environment
Updated on 2026-01-08 GMT+08:00
Configure a global runtime environment for a build task.
GUI Configuration
Configure the build environment.
The parameters are described in the following table.
| Parameter | Description |
| Environment | x86 server |
Code-based Build
The sample code is as follows:
1 2 3 4 5 6 7 | version: 2.0 # The version number is a mandatory and unique parameter that must be set to 2.0. env: # Optional. It defines the build environment. x86 is used by default if neither env or envs is set. resource: type:docker # Agent pool type. The value can be docker or custom. docker indicates that the default executor is used, and custom indicates that a custom executor is used. arch:X86 # The host type of the build environment can be either x86 or Arm. class:8 vCPUs | 16 GB # The specification can be: 2 vCPUs | 8 GB, 4 vCPUs | 8 GB, 8 vCPUs | 16 GB, 16 vCPUs | 32 GB, or 16 vCPUs | 64 GB. This parameter is not required when the agent pool type is set to a custom one. pool:Mydocker #Agent pool name. This parameter is required when the agent pool type is set to a custom one. |
Parent topic: Configuring Build Actions
