Using Grails for Build
In this action, you build a web application with Grails.
Graphical Build
Add Build with Grails, when configuring build actions.
The parameters are described in the following table.
| Parameter | Description |
| Action Name | Name of a build action. It can be customized. |
| Tool Version | Select a tool version. |
| Commands | Configure Grails commands. You can also use default commands. If you have special build requirements, enter your custom build script in the text box. |
Code-based Build
1 2 3 4 5 6 | version: 2.0 # The value must be 2.0. steps: BUILD: - grails: inputs: command: grails war |
| Parameter | Type | Description | Mandatory | Default Value |
| command | string | Commands to be run. | Yes | None |
