Running Shell Commands for Build
Graphical Build
Add Run Shell Commands, when configuring build actions.
The parameters are described in the following table.
| Parameter | Description |
| Action Name | Name of a build action. It can be customized. |
| Tool Version | Select a tool version. |
| Commands | Enter the command as required. |
Code-based Build
1 2 3 4 5 6 | version: 2.0 # The value must be 2.0. steps: PRE_BUILD: - sh: inputs: command: echo ${a} |
| Parameter | Type | Description | Mandatory | Default Value |
| command | String | Commands to be run. | Yes | None |
