Using GNU Arm for Build
Design, develop, and use an Arm simulator with the GNU Arm embedded toolchain.
Graphical Build
Add Build with GNU Arm, when configuring build actions.
The parameters are described in the following table.
| Parameter | Description |
| Action Name | Name of a build action. It can be customized. |
| Tool Version | Select an Arm tool version. |
| Commands | Configure the GNU Arm commands. You can also use the default make command.
Code-based Build
1 2 3 4 5 6 | version: 2.0 # The value must be 2.0. steps: BUILD: - gnu_arm: inputs: command: make |
| Parameter | Type | Description | Mandatory | Default Value |
| command | String | Commands to be run. | Yes | None |
