Using PHP for Build
In this action, you declare, install, and package the PHP libraries your project depends on by using the PHP runtime environment and Composer.
Graphical Build
Add Build in PHP, when configuring build actions.
The parameters are described in the following table.
| Parameter | Description |
| Action Name | Name of a build action. It can be customized. |
| Tool Version | Select a tool version. |
| Commands | Configure the PHP commands. You can also use default commands. If you have special build requirements, enter your custom build script in the text box. |
Code-based Build
| Parameter | Type | Description | Mandatory | Default Value |
| command | string | Commands to be run. | Yes | None |
