Updated on 2026-01-08 GMT+08:00
What Is CodeArts Build?
Build refers to the process of compiling source code into one or more object files, and packaging these object files along with configuration and resource files.
CodeArts Build provides an easy-to-use, cloud-based build platform that supports multiple programming languages, helping you achieve continuous delivery with higher efficiency. With just a few clicks, you can easily create, configure, and run build tasks to automate code retrieval, build, and packaging. CodeArts Build also monitors build status in real time.
Container-based build
CodeArts Build provides container-based build environments and supports two types of container images:
  • System images: provided by CodeArts Build for compilation and packaging with popular programming languages.
  • Custom images: customized for compilation and packaging with multiple languages and stored in SWR.
