What Is CodeArts Check?
CodeArts Check is a cloud-based service that checks code. With years of experience in automatic static check and enterprise application, CodeArts Check provides rich check services on code style, common quality, cyber security, and other elements. It also includes professional scan reports, convenient bug handling, and many other efficient, easy-to-use functions for enterprises to effectively improve code quality.
CodeArts Check Functions
| Function | Description |
| Coding issue check | Use rule sets to check issues in your own code. |
| Code security check | Use rule sets to check code security risks and issues. |
| Code style check | Use rule sets to check whether your code matches the selected style. |
| Issue management | Handle issues found in code checks based on issue descriptions, statuses, check rules, file paths, source code, and fix suggestions. |
| Cyclomatic complexity | Evaluate code quality risks based on the code cyclomatic complexity report. |
| NBNC (non-blank non-comment) | Number of valid lines of code (LOC) excluding blank lines and comment lines. |
| Duplication rate | Evaluate code quality risks based on the duplication rate report. |
| Scheduled check | Use the function of scheduling code checks every week and every day to balance rest and coding. |
| Check result notification | After the check is complete, the messages are sent to notify related personnel of the check results so that they can handle issues in time. |
| Check in multiple languages | Check code in Java, C++, JavaScript, Go, Python, C#, TypeScript, CSS, HTML, and PHP. |
IDE Plug-in of CodeArts Check
It is a powerful assistant for developers to protect the code quality.
- Provides industry standard (including Huawei Cloud) check, one-click code style formatting, and automatic code fixing, adhering to the concepts of simplicity, high speed, and real-time monitoring.
- Checks code accurately and efficiently, and builds three-layer protection during coding, merging, and version release with cloud services jointly.
- Displays all built-in lightweight IDE rules that are a subset of cloud rules in the cloud, implements security scan shifting left, and covers 30+ defect categories.
- Supports Java, C, C++, and Python. The IDE plug-in has been rolled out on four mainstream IDE platforms: VSCode IDE, IntelliJ IDEA, CodeArts IDE, and Cloud IDE.
