Updated on 2026-01-09 GMT+08:00
Configuring Excluded Flies
You can configure the file scope by task.
  • If you do not specify a file path, all code of the selected repository branch is checked.
  • If you specify a file path, the files in the specified path are ignored during a check.
  1. Go to the task page. In the task list, click a task name.
  2. On the displayed View Task Details page, click Settings > Check Modes.
  3. In the Ignored File List area, select the file paths that do not need to be checked.
  4. Run the code check task. The files in the selected paths will not be checked.
