Help Center/ CodeArts Check/ User Guide (Ally Region)/ User Guide/ (Optional) Configuring a Task/ Configuring a Rule Set
Updated on 2026-01-09 GMT+08:00
You can change code check rule sets as required. The new rule set takes effect in the next check.
- Go to the task page. In the task list, click a task name.
- On the displayed View Task Details page, click Settings > Rule Sets.
- In the Languages Included area, enable the target language. In the Enable Rule Set area, click the rule set which you want to change.
- For details about how to add a new rule set, see Custom Rule Set. After the rule set is added, refresh the page to obtain the rule set.
- In the displayed dialog box, click OK to change the language rule set.
- (Optional) To configure extended parameters for the selected rule set, click Check Parameter, configure extended parameter, enable the configuration function, and click OK.
Parent topic: (Optional) Configuring a Task
