Checking Code from CodeArts Repo
Consistent coding habits and styles make code easier to read and maintain. You can use CodeArts Check to verify compliance with platform or industry-specific coding specifications.
This sample demonstrates how to check the code from CodeArts Repo and guides you through using CodeArts Check.
Preparing a Repository in CodeArts Repo
- Log in to the CodeArts homepage.
- Click Create Project, and select the Scrum template. Set the project name to Scrum01 and retain the default values for other parameters. Click OK to access the project.
- In the navigation pane, choose .
- Click New Repository. Select Template, and click Next.
- Search for Java Ant Demo and select the template. Click Next.
- Set the repository name to Repo01 and deselect Automatically create Check task. Retain the default values for other parameters and click OK.
Creating and Executing a Check Task from CodeArts Repo
- Click Create Task. On the displayed page, set the following parameters and retain the default values for other parameters.
- Name: Customize a task name, for example, CheckTask01.
- Repository: Select the code repository Repo01 created in Preparing a Repository in CodeArts Repo.
- Language: Select the language of the code to be checked. Select Java in this sample.
- Click Start Check to execute the task.
Viewing Check Results
After the check is complete, the check results are displayed, including overview, issues, metrics, logs, and health status.
