Cppcheck Cannot Tokenize the Code Correctly
Symptom
Cppcheck cannot tokenize the code correctly is displayed during code check.
Cause Analysis
It is a rule of Cppcheck. The code contains syntax errors, which are caused by C code written using Java syntax.
Solution
The code must be written according to coding specifications of the C language and cannot contain the coding rules of other languages.
