Viewing Code Issues
After executing a code check task, you can modify the status of the code issues and transfer the owner in the issue list.
- Go to the task page. In the task list, click a task name.
- On the displayed View Task Details page, click the Issues tab. For details, see Table 1.
- In the Filters area on the left, you can filter issues by criteria and select one or multiple issues in the right area for separate, batch, or full operations.
- Click Owner to submit the issue to another owner.
- If an issue does not need to be modified, change the issue status to Ignore Issue.
- Click View Context. On the Context page, you can modify the issue status, transfer the owner, and click
to modify the code based on Help.
Table 1 Code issue description Operation
Issue Level
Includes Critical, Major, Minor, and Suggestion.
Issue Status
Includes Pending, Resolved, Ignored, and Fixed.
Check Time
Includes New and Inventory issues.
Language
Statistics are collected by programming language.
Rule
Statistics are collected based on matched rules so that users can fix the same type of issues at a time.
User Tag
Statistics are collected by user tag of rules.
Owner
Statistics are collected by assigned issue owner.
CWE
Statistics are collected by security rule name.
File
Search for code issues by source file.
Generate Report
Download the check report as an attachment to your local host.
Export All
Choose All Change > Export All to export all filtered code issues.
Change Statuses
Change the status of all code issues to Resolved or Ignore Issue.
NOTE:If the number of code issues is 0, this button is not displayed.
Change Owners
Transfer all code issues to other owners.
Handle specified issues in batches
Select the target issues and click Batch Transfer Owner, Modify problem status in batches, or Export.
