Homepage Overview
CodeArts provides an entry for each subservice. You can manage your projects, and configure personal and tenant settings.
Navigation Bar
CodeArts provides multiple choices of themes and layouts. This section uses "Infinite and Classics" as an example to introduce the navigation bar.
Menu |
Description |
The entry for each service so that you can go to their homepage. |
Console |
The console is displayed. You can select other products as required. |
Homepage |
Go to the CodeArts homepage. |
Workspace |
View the work items under your account. For details, see Workspace. |
Services |
Provides an entry for each service of CodeArts so that you can go to their homepage. |
View notification messages about operations on each service. |
View the user guide of each service. |
Summary of your to-do items. |
Projects
All projects in which you are involved are displayed. The project list displays followed, all, and archived projects on different tabs.
- Followed projects: projects marked with
- All projects: all projects in which you have joined
- Archived projects: projects that have been archived on the page
You can perform the following operations.
Operation |
Description |
Create a project |
To create a project, you must have the project creator permission. For details about how to configure the permission, see Project Creators. Click Create Project and select a project type. |
Add a project to a group |
Search for a project |
Enter a keyword in the search box above the project list. |
Switch the display mode |
Projects can be displayed in card view or list view. Click |
