Connecting to the HBase Cluster Through the Thrift Server
The HBase Thrift Server operates as a service within the HBase cluster, offering a gateway to the HBase database via the Thrift protocol. This server is adept at producing both client and server code, accommodating a multitude of programming languages for diverse application needs.
- The Thrift Server supports the following programming languages: Python and C++.
- The Thrift Server does not support features such as cold and hot data separation, automatic hotspot self-healing, or secondary indexing.
- Thrift Server is deployed only on Core nodes.
- Scaling out the Thrift Server is directly dependent on the scaling capabilities of the Core nodes.
- If the Thrift Server encounters issues, services may be disrupted, especially when it is accessed via IP addresses.
- The Thrift Serve feature is supported in only HBase 2.4.14 or later.
- Thrift Server is disabled by default.
- You have created an HBase cluster.
- The cluster status is In Service.
Procedure for Enabling Thrift Server
- Log in to the CloudTable console.
- Select a region in the upper left corner.
- Click Buy Cluster in the upper right corner.
- Go to the Create Cluster page. On the cluster purchase page, select the HBase database engine and enable Thrift Server.
You can also choose More > Enable Thrift Server in the Operation column on the cluster management page to enable Thrift Server.
- Click the target cluster name. In the Cluster Information area on the cluster details page, obtain the Thrift Server IP address.
- Select the runtime language and configure the IP address.
Procedure for Disabling Thrift Server
- Select the cluster for which you want to disable Thrift Server and choose More > Disable Thrift Server.
- In the displayed window for disabling the Thrift Server service, click OK.
