Checking the ClickHouse Cluster Status
You can check the cluster status on the console. In the navigation pane, click Cluster Management. On the Cluster Management page, a cluster list is displayed. If there are a large number of clusters, you can turn pages to view clusters in any state.
| Parameter | Description |
| Cluster Name | Cluster name specified when a cluster is created. |
| High Availability | If cluster HA or "Single Replica and Multi Shard" is enabled when a ClickHouse cluster is created, "The cluster can be used only for testing services." is displayed. If it is not enabled, "--" is displayed. |
| Cluster Status | Cluster status, including Creating, In service, Sub-health, and Creation failed. |
| Task Status | Task status of a cluster. |
| Database Engine | ClickHouse |
| Version | Cluster version. |
| Enterprise Project | You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project. NOTE:
| Created | Time when a cluster is created. |
| Billing Mode | Billing mode of a cluster, which can. |
| Operation |
| Icon | Description |
| Click |
| Click |
| Enter a cluster name in the search box and click |
Cluster Status
| Status | Description |
| Creating | Indicates that a cluster is being created. |
| In service | If a cluster is successfully created and can provide services, the cluster status is In service. |
| Sub-health | If the cluster status cannot be monitored within the specified time, the cluster status changes to Sub-health. Manual intervention is required to recover a cluster that is in Sub-health status. For example, you can restart the cluster to recover the cluster. |
| Creation failed | Indicates that a cluster fails to be created. |
Task Status
| Deleting | Indicates that a cluster is being deleted. |
| Restarting | Indicates that a cluster is being restarted. |
| Scaling out | Indicates that a cluster is being scaled out. |
