Updated on 2026-01-09 GMT+08:00
ClickHouse Usage Process
ClickHouse is a columnar database oriented to online analysis and processing. It is independent of the Hadoop big data system and features compression rate and fast query performance. In addition, ClickHouse supports SQL query and provides good query performance, especially the aggregation analysis and query performance based on large and wide tables. The query speed is one order of magnitude faster than that of other analytical databases. CloudTable ClickHouse cluster management also provides the following functions:
In ClickHouse cluster management, you need to create a dedicated cluster and can use it on demand. Dedicated clusters are physically isolated and are not affected by other services, facilitating user management.
After the ClickHouse cluster is created, use the client to access the cluster. For details, see the following sections.
