Updated on 2026-01-09 GMT+08:00
Doris Usage Process
The CloudTable cluster mode provides a distributed, scalable, and fully managed Doris-based real-time data warehouse. It returns mass data query results within subseconds and supports high-concurrency point queries and high-throughput complex analysis.
In Doris cluster management, you need to create a dedicated cluster and can use it on demand. Dedicated clusters are physically isolated and are not affected by other services, facilitating user management.
After a Doris cluster is created, you can use a client to access the cluster. For details, see Connecting to a Doris Cluster.
Table 1 Doris Usage Process
Step
Substep
Detailed Instructions
Preparations
Creating a user and granting permissions
  • Before using CloudTable Doris, you need to register a cloud account and grant the necessary permissions to your account.
  • Grant the necessary service permissions to a user group, and then add users to this group to enable their access.
Creating a User and Granting Permissions
Creating a cluster
Creating a Doris cluster
Before using Doris to execute tasks, you need to create a Doris cluster.
Creating a Doris Cluster
Downloading the client
Downloading the Doris client
After creating a cluster, download and install the client. After the client is installed, you can use the SSH tool to connect to the cluster.
Preparing an ECS
If the client tool runs on Linux, you need to prepare a Linux ECS that is in the VPC as a Doris cluster and the Linux ECS serves as a client host.
If the client tool runs on Windows, you need to prepare a Windows ECS that is in the VPC as a Doris cluster and the Windows ECS serves as a client host.
Preparing an ECS
Installing the client
Place the downloaded client on the ECS, decompress the package, and install the client.
Using the MySQL Client to Connect to a Doris Normal Cluster
Connecting to the cluster
After installing the MySQL client on the ECS, you can run commands to connect to the cluster and perform service operations.
