Container Metrics and Dimensions
| Metric | Description | Value Range | Unit |
| Total CPU cores (aom_container_cpu_limit_core) | Total number of CPU cores restricted for a measured object | ≥ 1 | Cores |
| Used CPU cores (aom_container_cpu_used_core) | Number of CPU cores used by a measured object | ≥ 0 | Cores |
| CPU usage (aom_container_cpu_usage) | CPU usage of a measured object. That is, the percentage of the used CPU cores to the total CPU cores restricted for a measured object. | 0–100 | % |
| Disk read rate (aom_container_disk_read_kilobytes) | Volume of data read from a disk per second | ≥ 0 | KB/s |
| Disk write rate (aom_container_disk_write_kilobytes) | Volume of data written into a disk per second | ≥ 0 | KB/s |
| Available file system capacity (aom_container_filesystem_available_capacity_megabytes) | Available file system capacity of a measured object. This metric is available only for containers using the Device Mapper storage drive in the Kubernetes cluster of version 1.11 or later. | ≥ 0 | MB |
| Total file system capability (aom_container_filesystem_capacity_megabytes) | Total file system capacity of a measured object. This metric is available only for containers using the Device Mapper storage drive in the Kubernetes cluster of version 1.11 or later. | ≥ 0 | MB |
| File system usage (aom_container_filesystem_usage) | File system usage of a measured object. That is, the percentage of the used file system to the total file system. This metric is available only for containers using the Device Mapper storage drive in the Kubernetes cluster of version 1.11 or later. | 0–100 | % |
| Total GPU memory (aom_container_gpu_memory_free_megabytes) | Total GPU memory of a measured object | > 0 | MB |
| GPU memory usage (aom_container_gpu_memory_usage) | Percentage of the used GPU memory to the total GPU memory | 0–100 | % |
| Used GPU memory (aom_container_gpu_memory_used_megabytes) | GPU memory used by a measured object | ≥ 0 | MB |
| GPU usage (aom_container_gpu_usage) | GPU usage of a measured object | 0–100 | % |
| Total NPU memory (aom_container_npu_memory_free_megabytes) | Total NPU memory of a measured object | > 0 | MB |
| NPU memory usage (aom_container_npu_memory_usage) | Percentage of the used NPU memory to the total NPU memory | 0–100 | % |
| Used NPU memory (aom_container_npu_memory_used_megabytes) | NPU memory used by a measured object | ≥ 0 | MB |
| NPU usage (aom_container_npu_usage) | NPU usage of a measured object | 0–100 | % |
| Total physical memory (aom_container_memory_request_megabytes) | Total physical memory restricted for a measured object | ≥ 0 | MB |
| Physical memory usage (aom_container_memory_usage) | Percentage of the used physical memory to the total physical memory restricted for a measured object | 0–100 | % |
| Used physical memory (aom_container_memory_used_megabytes) | Used physical memory of a measured object | ≥ 0 | MB |
| Downlink rate (BPS) (aom_container_network_receive_bytes) | Inbound traffic rate of a measured object | ≥ 0 | Byte/s |
| Downlink rate (PPS) (aom_container_network_receive_packets) | Number of data packets received by a NIC per second | ≥ 0 | Packet/s |
| Downlink error rate (aom_container_network_receive_error_packets) | Number of error packets received by a NIC per second | ≥ 0 | Count/s |
| Error packets (aom_container_network_rx_error_packets) | Number of error packets received by a measured object | ≥ 0 | Count |
| Uplink rate (BPS) (aom_container_network_transmit_bytes) | Outbound traffic rate of a measured object | ≥ 0 | Byte/s |
| Uplink error rate (aom_container_network_transmit_error_packets) | Number of error packets sent by a NIC per second | ≥ 0 | Count/s |
| Uplink rate (PPS) (aom_container_network_transmit_packets) | Number of data packets sent by a NIC per second | ≥ 0 | Packet/s |
| Status (aom_process_status) | Docker container status | 0 or 1
| N/A |
| Working set memory usage (aom_container_memory_workingset_usage) | Usage of the working set memory | 0–100 | % |
| Used working set memory (aom_container_memory_workingset_used_megabytes) | Sum of resident set size (RSS) memory and cache | ≥ 0 | MB |
| Dimension | Description |
| appID | Service ID |
| appName | Service name |
| clusterId | Cluster ID |
| clusterName | Cluster name |
| containerID | Container ID |
| containerName | Container name |
| deploymentName | Kubernetes deployment name |
| kind | Application type |
| nameSpace | Cluster namespace |
| podID | Instance ID |
| podName | Instance name |
| serviceID | Inventory ID |
| gpuID | GPU ID |
| npuName | NPU name |
| npuID | NPU ID |
