Updated on 2026-01-09 GMT+08:00
weekday
This function is used to return the day of the current week.
Syntax
weekday (string date)
Parameters
Table 1 Parameter
Mandatory
Type
date
Yes
DATE or STRING
Date that needs to be processed
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
Return Values
The return value is of the INT type.
  • If Monday is used as the first day of a week, the value 0 is returned. For other weekdays, the return value increases in ascending order. For Sunday, the value 6 is returned.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of date is NULL, NULL is returned.
Example Code
The value 2 is returned.
select weekday ('2023-08-16 10:54:36');
The value NULL is returned.
select weekday (null);
