Updated on 2026-01-09 GMT+08:00
sum
This function is used to calculate the total sum.
Syntax
sum(col),
sum(DISTINCT col)
Parameters
Table 1 Parameter
Mandatory
col
Yes
The value can be of any data type and can be converted to the DOUBLE type for calculation.
The value can be of the DOUBLE, DECIMAL, or BIGINT type.
If the value is of the STRING type, the system implicitly converts it to DOUBLE for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of col is NULL, the row is not involved in calculation.
Example Code
  • Calculates the total number of offerings (items) in all warehouses. An example command is as follows:
    select sum(items) from warehouse;
    The command output is as follows:
    _c0
    55357
  • When used with group by, it groups all offerings by warehouse (warehouseId) and calculates the total number of offerings in all warehouses. An example command is as follows:
    select warehouseId, sum(items) from warehouse group by warehouseId;
    warehouseId| _c1
    city1    15500
    city2    10175
    city3    19400
