Updated on 2026-01-09 GMT+08:00
rand
This function is used to return an evenly distributed random number that is greater than or equal to 0 and less than 1.
Syntax
rand(INT seed)
Parameters
Table 1 Parameter
Mandatory
Type
seed
No
INT
The value can be a float, integer, or string.
If this parameter is specified, a stable random number sequence is obtained within the same running environment.
Return Values
The return value is of the DOUBLE type.
Example Code
The value 0.3668915240363728 is returned.
select rand();
The value 0.25738143505962285 is returned.
select rand(3);
