Updated on 2026-01-09 GMT+08:00
radians
This function is used to return the radian corresponding to an angle.
Syntax
radians(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1.0471975511965976 is returned.
select radians(60);
The value 0 is returned.
select radians(0);
The value NULL is returned.
select radians(null);
