Updated on 2026-01-09 GMT+08:00
from_unixtime
This function is used to convert a timestamp represented by a numeric UNIX value to a date value.
Syntax
from_unixtime(bigint unixtime)
Parameters
Table 1 Parameter
Mandatory
Type
unixtime
Yes
BIGINT
Timestamp to be converted, in UNIX format
Set this parameter to the first 10 digits of the timestamp in UNIX format.
Return Values
The return value is of the STRING type, in the yyyy-mm-dd hh:mi:ss format.
If the value of unixtime is NULL, NULL is returned.
Example Code
The value 2023-08-16 09:39:57 is returned.
select from_unixtime(1692149997);
The value NULL is returned.
select from_unixtime(NULL);
Example table data
select unixdate, from_unixtime(unixdate) as timestamp_from_unixtime from database_t;
Output:
| unixdate              | timestamp_from_unixtime   |
| 1690944759224  | 2023-08-02 10:52:39           |
| 1690944999811  | 2023-08-02 10:56:39           |
| 1690945005458  | 2023-08-02 10:56:45           |
| 1690945011542  | 2023-08-02 10:56:51           |
| 1690945023151  | 2023-08-02 10:57:03           |
