Updated on 2026-01-09 GMT+08:00
datepart
This function is used to calculate the value that meets the specified datepart in date.
Syntax
datepart (string date, string datepart)
Parameters
Table 1 Parameters
Mandatory
Type
date
Yes
DATE
or
STRING
Start date
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
datepart
Yes
STRING
Time unit of the value to be returned
This parameter supports the following extended date formats: year, month or mon, day, and hour.
  • yyyy indicates the year.
  • MM indicates the month.
  • dd indicates the day.
  • hh indicates the hour.
  • mi indicates the minute.
  • ss indicates the second.
Return Values
The return value is of the BIGINT type.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of datepart is NULL, NULL is returned.
Example Code
The value 2023 is returned.
select datepart(date '2023-08-14 17:00:00', 'yyyy');
select datepart('2023-08-14 17:00:00', 'yyyy');
The value 59 is returned.
select datepart('2023-08-14 17:59:59', 'mi')
The value NULL is returned.
select datepart(date '2023-08-14', null);
