Updated on 2026-01-09 GMT+08:00
cos
This function is used to calculate the cosine value of a, with input in radians.
Syntax
cos(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value -0.9999999999999986 is returned.
select cos(3.1415926);
The value NULL is returned.
select cos(null);
