Updated on 2026-01-09 GMT+08:00
asin
This function is used to return the arc sine value of a given angle a.
Syntax
asin(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value range is [-1,1]. The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type. The value ranges from -π/2 to π/2.
  • If the value of a is not within the range [-1,1], NaN is returned.
  • If the value of a is NULL, NULL is returned.
Example Code
The value 1.5707963267948966 is returned.
select asin(1);
The value 0.6435011087932844 is returned.
select asin(0.6);
The value NULL is returned.
select asin(null);
The value NAN is returned.
select asin(10);
