Client-Side Encryption APIs (SDK for Python)
Initializing CryptoCipher
The OBS SDK for Python offers two types of CryptoCipher. Choose the one right for you.
CtrRSACipherGenerator needs an RSA public or private key to encrypt the randomly generated data key.
Method
CtrRSACipherGenerator(master_crypto_key_path, master_key_info=None, need_sha256=False)
API Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| master_crypto_key_path | str | Yes | Explanation: Path where the RSA key file is stored Default value: None |
| master_key_info | str | No | Explanation: Key information, which is stored in the custom metadata of objects to help you distinguish different data keys. You need to maintain the mapping between master_key_info and crypto_key. Default value: None |
| need_sha256 | bool | No | Explanation: Whether to verify the SHA-256 value of the encrypted data and to add SHA-256 values calculated before and after the encryption to the custom metadata NOTE: To reduce memory overheads, the SDK uses streaming computing, which means that a file needs to be read and encrypted twice in a common upload and three times in a resumable upload. Value range: True: The SHA-256 value of the encrypted data is verified. The SDK automatically calculates SHA-256 before and after the object is encrypted and saves the two values to the custom metadata of the object. In addition, the SDK adds the SHA-256 value of the encrypted object to the request header when sending a request to the server. After receiving the request, the server calculates the SHA-256 value of the object and checks the consistency between the calculated and the received values. If they are inconsistent, an error message is returned. False: The SHA-256 value of the encrypted data is not verified. Default value: False |
CTRCipherGenerator requires only a data key. This key is used to encrypt all objects.
Method
CTRCipherGenerator(crypto_key, master_key_info=None, crypto_iv=None, need_sha256=False)
API Parameters
| crypto_key | str or bytes | Yes | Explanation: Data key used for encrypting data Restrictions:
| crypto_iv | str or bytes | No | Explanation: Initial value used for encrypting data Restrictions:
| need_sha256 | bool | No | Explanation: Whether to verify the SHA-256 value of the encrypted data and to add SHA-256 values calculated before and after the encryption to the custom metadata NOTE: To reduce memory overheads, the SDK uses streaming computing, which means that a file needs to be read and encrypted twice during a common upload, but in a resumable upload, a file needs to be read and encrypted three times. Value range: True: The SHA-256 value of the encrypted data is verified. The SDK automatically calculates SHA-256 before and after the object is encrypted and saves the two values to the custom metadata of the object. In addition, the SDK adds the SHA-256 value of the encrypted object to the request header when sending a request to the server. After receiving the request, the server calculates the SHA-256 value of the object and checks the consistency between the calculated and the received values. If they are inconsistent, an error message is returned. False: The SHA-256 value of the encrypted data is not verified. Default value: False |
Initializing CryptoClient
Initializing CryptoClient is inherited from initializing an ObsClient. For details, see Initializing an Instance of ObsClient (SDK for Python).
Method
CryptoClient(access_key_id,secret_access_key,server,cipher_generator=your-cipher_generator, *args, **kwargs)
API Parameters
| Parameter | Description | Recommended Value |
| access_key_id | Explanation: Access key ID (AK) Default value: An empty string, indicating an anonymous user | N/A |
| secret_access_key | Explanation: Secret access key (SK) Default value: An empty string, indicating an anonymous user | N/A |
| server | Explanation: Server address for accessing OBS. It consists of a protocol type, domain name, and port number, for example, https://your-endpoint:443. For security purposes, you are advised to use HTTPS. Default value: None | N/A |
| cipher_generator | Explanation: Cipher generator used by a client Value range: Default value: None | N/A |
Initiating an Encrypted Multipart Upload
Initiating an encrypted multipart upload is inherited from the ObsClient API for initiating a multipart upload. For details, see Initiating a Multipart Upload (SDK for Python).
Method
CryptoClient.initiateEncryptedMultipartUpload(bucketName, objectKey, crypto_cipher, *args, **kwargs)
API Parameters
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
| objectKey | str | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. Value range: The value must contain 1 to 1,024 characters. Default value: None NOTE: The object URL is in the following format: https://Bucket name.Domain name/Folder directory level/Object name. If this object is stored in the root directory of the bucket, its URL does not contain the folder directory level. |
| crypto_cipher | OBSCipher | Yes | Explanation: OBS cipher generated by calling cipher_generator.new(). Configure this parameter into the metadata during task initiation. Value range: A value generated by calling cipher_generator.new(). cipher_generator is the cipher_generator parameter set for CryptoClient initialization. Example: cipher = ctr_client.cipher_generator.new(""). ctr_client is the encryption client. Default value: None |
Uploading an Encrypted Part
Uploading encrypted parts is inherited from the ObsClient API for uploading parts. For details, see Uploading a Part (SDK for Python).
Method
CryptoClient.initiateEncryptedMultipartUpload(bucketName, objectKey, partNumber, uploadId, crypto_cipher, *args, **kwargs)
API Parameters
| partNumber | int | Yes | Explanation: Part number Value range: [1,10000] Default value: None |
| uploadId | str | Yes | Explanation: Multipart upload ID, which can be returned by initiating a multipart upload, for example, 000001648453845DBB78F2340DD460D8 Restrictions: The value must contain 32 characters. Default value: None |
| crypto_cipher | OBSCipher | Yes | Explanation: OBS cipher generated by calling cipher_generator.new() Value range: A value generated by calling cipher_generator.new(). cipher_generator is the cipher_generator parameter set for CryptoClient initialization. Example: cipher = ctr_client.cipher_generator.new(""). ctr_client is the encryption client. Default value: None |
