Modifying Object Metadata (SDK for Python)
Function
Object metadata is a set of name-value pairs that describe the object and is used for object management.
Currently, only the system-defined metadata can be modified.
System-defined metadata consists of system-controlled metadata and user-controlled metadata. The kind of metadata like Last-Modified is controlled by the system and cannot be modified. However, the kind of metadata configured for objects such as ContentLanguage can be modified by calling APIs.
This API modifies, deletes, or adds metadata to objects in a bucket.
Restrictions
- To configure object metadata, you must be the bucket owner or have the required permission (obs:object:ModifyObjectMetaData in IAM or ModifyObjectMetaData in a bucket policy).
- If versioning is enabled for a bucket, you can set metadata for objects of the latest version, but cannot set metadata for objects of historical versions.
- You cannot set metadata for objects.
Method
ObsClient.setObjectMetadata(bucketName, objectKey, metadata, headers, versionId, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
objectKey |
str |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. Value range: The value must contain 1 to 1,024 characters. Default value: None |
metadata |
dict |
No |
Explanation: Custom metadata of the object. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
headers |
No |
Explanation: Request headers for configuring object metadata. For details, see Table 2. |
versionId |
str |
No |
Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A Value range: The value must contain 32 characters. Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
Parameter |
Type |
Description |
removeUnset |
bool |
No |
Explanation: Used to set the metadata operation indicator Value range: True: The metadata operation indicator is REPLACE. REPLACE uses the complete header carried in the current request to replace the original one and deletes the metadata that is not specified. False: The metadata operation indicator is REPLACE_NEW. REPLACE_NEW replaces the metadata that already has a value, assigns a value to the metadata that does not have a value, and retains the metadata that is not specified. Default value: False |
location |
str |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
cacheControl |
str |
No |
Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
contentDisposition |
str |
No |
Explanation: Content-Disposition header in the response It specifies the name of an object when it is downloaded. Default value: None |
contentEncoding |
str |
No |
Explanation: Content-Encoding header in the response It specifies the content encoding format when an object is downloaded. Default value: None |
contentLanguage |
str |
No |
Explanation: Content-Language header in the response It specifies the content language format when an object is downloaded. Default value: None |
contentType |
str |
No |
Explanation: Content-Type header in the response. It specifies the file type of an object when it is downloaded. Default value: None |
expires |
str |
No |
Explanation: Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded.
CAUTION:
This parameter cannot be used to configure the expiration time of an object. To configure the object expiration time, see Setting an Object Expiration Time (SDK for Python). Default value: None |
storageClass |
str |
No |
Explanation: Storage classes Value range: See Table 3. Default value: None |
Parameter |
Type |
Description |
STANDARD |
Standard storage class |
Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
WARM |
Warm storage class |
Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
COLD |
Cold storage class |
Explanation: Used for storing rarely accessed (once a year) data. |
INTELLIGENT_TIERING |
Intelligent Tiering |
Explanation: Is designed to optimize storage costs by automatically moving data to a more economical access tier when data access patterns change. This storage class is ideal for data with constantly changing or unpredictable access patterns. |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
Code Examples
This example configures the object metadata.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
from obs import SetObjectMetadataHeader from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint of the region where the bucket is located. server = "https://your-endpoint" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify custom metadata. metadata = {'property1': 'property-value1', 'property2': 'property-value2'} # Specify the additional headers of the request for configuring object metadata. headers = SetObjectMetadataHeader() # (Optional) Specify the MIME type of the object. headers.contentType = "Your Content-Type" bucketName = "examplebucket" objectKey = "objectname" # Configure metadata for the object. resp = obsClient.setObjectMetadata(bucketName, objectKey, metadata, headers) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Set Object Metadata Succeeded') print('requestId:', resp.requestId) else: print('Set Object Metadata Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Set Object Metadata Failed') print(traceback.format_exc()) |
