Uploading an Object - Browser-Based (SDK for Python)
Function
This API uploads an object up to 5 GB to a specified bucket in HTML form. You can call ObsClient.createPostSignature to generate parameters for requesting a browser-based upload.
- Call ObsClient.createPostSignature to generate request parameters for authentication.
- Prepare an HTML form.
- Enter the request parameters in the page.
- Select a local file and upload it in browser-based mode.
There are two request parameters generated for authentication:
- policy, which corresponds to the policy parameter in the form.
- signature, which corresponds to the signature parameter in the form.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy).
- Values of policy and signature in the HTML form are obtained from the returned results of ObsClient.createPostSignature.
Method
ObsClient.createPostSignature(bucketName, objectKey, expires, formParams)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
bucketName | str | No | Explanation: Bucket name Restrictions:
Default value: None |
objectKey | str | No | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. Value range: The value must contain 1 to 1,024 characters. Default value: None |
expires | int | No | Explanation: Expiration time of authentication for a browser-based upload Value range: A positive integer, in seconds Default value: 300 |
formParams | dict | No | Explanation: Parameters of browser-based uploads, not including key, policy, and signature. Value range: (When you use the following parameters, you must add the x-obs prefix to them. Taking acl as an example, it should be configured as formParams['x-obs-acl']='public-read'. To obtain the values of these parameters, see the response header descriptions in APIs.)
Responses
Parameter | Type | Description |
originPolicy | str | Explanation: Value of Policy that is not encoded by Base64. This parameter can only be used for verification. For example: {"expiration":"2023-09-12T12:52:59Z","conditions":[{"content-type":"text/plain"},{"bucket":"examplebucket"},{"key":"example/objectname"},]}" Default value: None |
policy | str | Explanation: Value of Policy that is encoded by Base64. For example: eyJleHBpcmF0aW9uIjoiMjAyMy0wOS0xMlQxMjo1Mjo1OVoiLCJjb25kaXRpb25zIjpbeyJjb250ZW50LXR5cGUiOiJ0ZXh0L3BsYWluIn0seyJidWNrZXQiOiJleGFtcGxlYnVja2V0In0seyJrZXkiOiJleGFtcGxlL29iamVjdG5hbWUifSxdfQ== Default value: None |
signature | str | Explanation: signature in the form For example: g0jQr4v9VWd1Q2FOFDG6LGfV9Cw= Default value: None |
Code Examples
This example generates authentication parameters policy and signature for a browser-based upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 | from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint of the region where the bucket is located. server = "https://your-endpoint" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" objectKey = "objectname" # Configure the validity period (in seconds) for a browser-based upload request. 3600 is used as an example. expires = 3600 # Specify parameters for a browser-based upload except key, policy, and signature. In this example, x-obs-acl is set to private and content-type is set to text/plain. formParams = {'x-obs-acl': 'private', 'content-type': 'text/plain'} # Create parameters for a browser-based upload. resp = obsClient.createPostSignature(bucketName, objectKey, expires, formParams) print('originPolicy:', resp.originPolicy) print('policy:', resp.policy) print('signature:', resp.signature) except: print(traceback.format_exc()) |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 | <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> </head> <body> <form action="http://bucketname.your-endpoint/" method="post" enctype="multipart/form-data"> <p> Object key </p> <!-- Object name --> <input type="text" name="key" value="objectname" /> <p> ACL </p> <!-- Object ACL --> <input type="text" name="x-obs-acl" value="private" /> <p> Content-Type </p> <!-- Object MIME type --> <input type="text" name="content-type" value="text/plain" /> <p> <!-- Base64-encoded policy --> <input type="hidden" name="policy" value="*** Provide your policy ***" /> <!-- AK --> <input type="hidden" name="AccessKeyId" value="*** Provide your access key ***"/> <!-- Signature string information --> <input type="hidden" name="signature" value="*** Provide your signature ***"/> <input name="file" type="file" /> <input name="submit" value="Upload" type="submit" /> </p> </form> </body> </html> |
