Obtaining Static Website Hosting for a Bucket (SDK for Python)
Function
You can host static website resources such as HTML web pages, flash files, as well as audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests
This API returns the static website hosting configuration of the bucket.
Restrictions
- To obtain the static website hosting configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketWebsite in IAM or GetBucketWebsite in a bucket policy).
Method
ObsClient.getBucketWebsite(bucketName, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| extensionHeaders | dict | No | Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
Responses
| Type | Description |
| Explanation: SDK common results |
| Parameter | Type | Description |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). Default value: None |
| reason | str | Explanation: Reason description. Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server. Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
| GetResult.body Type | Description |
| Explanation: Website hosting settings of a bucket |
| redirectAllRequestTo | No if used as a request parameter | Explanation: Redirection rules for all requests. For details, see Table 3. | |
| indexDocument | No if used as a request parameter | Explanation: Default page configuration. For details, see Table 4. | |
| errorDocument | No if used as a request parameter | Explanation: Error page configuration. For details, see Table 5. | |
| routingRules | list of RoutingRule | No if used as a request parameter | Explanation: List of routing rules. For details, see Table 6. |
- errorDocument, indexDocument, and routingRules must be used together and they cannot be used with redirectAllRequestsTo.
- When errorDocument, indexDocument, and routingRules are used together, routingRules can be left blank.
- You must specify either the combo of fields ErrorDocument, IndexDocument, and RoutingRules, or the RedirectAllRequestsTo field.
| hostName | str | Yes if used as a request parameter | Explanation: Host name used for redirection, for example, www.example.com Restrictions: The host name must comply with the host name rules. Default value: None |
| protocol | str | No if used as a request parameter | Explanation: Protocol used for redirection Value range:
| suffix | str | Yes if used as a request parameter | Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Value range: This parameter can neither be left blank nor contain slashes (/). Default value: None |
| key | str | No if used as a request parameter | Explanation: Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| condition | No if used as a request parameter | Explanation: Conditions that must be met for the specified redirect to apply Value range: See Table 7. Default value: None | |
| redirect | Yes if used as a request parameter | Explanation: Details about the redirection. For details, see Table 8. Default value: None |
| keyPrefixEquals | str | No if used as a request parameter | Explanation: Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect. For example, to redirect the requests for the object ExamplePage.html, set KeyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with httpErrorCodeReturnedEquals. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| httpErrorCodeReturnedEquals | int | No if used as a request parameter | Explanation: HTTP error code for the redirection to take effect. If there is an error, and the error code returned is the same as the value specified for this parameter, the redirection rule takes effect. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set httpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with keyPrefixEquals. Default value: None |
| hostName | str | No if used as a request parameter | Explanation: Host name used for redirection Default value: None |
| replaceKeyPrefixWith | str | No if used as a request parameter | Explanation: Object name prefix used in the redirection request Value range: The value must contain 1 to 1,024 characters. Default value: None |
| replaceKeyWith | str | No if used as a request parameter | Explanation: Object name used in the redirection request Restrictions: This parameter cannot be used together with replaceKeyPrefixWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| httpRedirectCode | int | No if used as a request parameter | Explanation: HTTP status code in the response to the redirect request. Default value: None |
Code Examples
This example returns the static website hosting configuration of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 | from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint of the region where the bucket is located. server = "https://your-endpoint" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName="examplebucket" # Obtain the website configuration of the bucket. resp = obsClient.getBucketWebsite(bucketName) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Get Bucket Website Succeeded') print('requestId:', resp.requestId) if resp.body.redirectAllRequestTo: print('redirectAllRequestTo.hostName:', resp.body.redirectAllRequestTo.hostName, ',redirectAllRequestTo.protocol:', resp.body.redirectAllRequestTo.protocol) if resp.body.indexDocument: print('indexDocument.suffix:', resp.body.indexDocument.suffix) if resp.body.errorDocument: print('errorDocument.key:', resp.body.errorDocument.key) if resp.body.routingRules: index = 1 for rout in resp.body.routingRules: print('routingRule[', index, ']:') index += 1 print('condition.keyPrefixEquals:', rout.condition.keyPrefixEquals, ',condition.httpErrorCodeReturnedEquals:', rout.condition.httpErrorCodeReturnedEquals) print('redirect.protocol:', rout.redirect.protocol, ',redirect.hostName:', rout.redirect.hostName, ',redirect.replaceKeyPrefixWith:', rout.redirect.replaceKeyPrefixWith, ',redirect.replaceKeyWith:', rout.redirect.replaceKeyWith, ',redirect.httpRedirectCode:', rout.redirect.httpRedirectCode) else: print('Get Bucket Website Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Get Bucket Website Failed') print(traceback.format_exc()) |
