Help Center/ Object Storage Service/ Python SDK Developer Guide (Ally Region)/ Before You Start (SDK for Python)
Updated on 2026-01-16 GMT+08:00
This section describes the important notes about Object Storage Service (OBS) SDK for Python.
Important Notes
- Some features are available only in some regions. If 405 HTTP status code is returned for a call of a certain feature API, check whether the region supports this feature.
- The namespace is incompatible with earlier OBS versions (2.1.x). All modules are saved in the obs package.
- API functions are compatible with earlier OBS versions (2.1.x).
