Help Center/ Object Storage Service/ Node.js SDK Developer Guide (Ally Region)/ Troubleshooting (SDK for Node.js)/ Connection Timeout (SDK for Node.js)
Updated on 2026-01-16 GMT+08:00
Problem: If a "connect ETIMEDOUT" error occurred when calling an API, the possible cause was that the service address (endpoint) was incorrect or the network was disconnected.
Solution:
- Check whether the service address was left blank or invalid.
- Check the network connection.
- Check whether the server had returned any exceptions and if so, contact the server-side O&M team.
Parent topic: Troubleshooting (SDK for Node.js)
