SDK Common Results (SDK for Node.js)
After you call an API in an instance of the ObsClient class, a common result object will be returned if no exception is thrown. The following table lists the fields of the object:
| Parameter | Type | Description | |
| CommonMsg | Object | Common information generated after the API is called, including HTTP status code and error code. | |
| - | Status | Number | HTTP status code. If the value is smaller than 300, the operation succeeds. Otherwise, the operation fails. |
| Code | String | Error code returned by the OBS server. If Status is smaller than 300, the value is null. | |
| Message | String | Error description returned by the OBS server. If Status is smaller than 300, the value is null. | |
| HostId | String | Requested Server ID. If Status is smaller than 300, the value is null. | |
| RequestId | String | Request ID returned by the OBS server | |
| Id2 | String | Request ID2 returned by the OBS server | |
| Indicator | String | Detailed error code returned by the OBS server. If Status is smaller than 300, the value is null. | |
| InterfaceResult | Object | Result data generated after the operation is successful. If Status is greater than 300, the value is null. | |
| - | RequestId | String | Request ID returned by the OBS server. |
| Other fields | For details, see the Response area in the corresponding section. | ||
Sample code:
// Import the OBS library.
// Use npm to install the client.
var ObsClient = require('esdk-obs-nodejs');
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
//Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
//Obtain an AK/SK pair on the management console.
access_key_id: process.env.ACCESS_KEY_ID,
secret_access_key: process.env.SECRET_ACCESS_KEY,
server : 'https://your-endpoint'
// Call APIs to perform operations, such as downloading an object.
obsClient.getObject({
Bucket : 'bucketname',
Key : 'objectname',
}, (err, result) => {
if(!err){
if(result.CommonMsg.Status < 300){
// Obtain RequestId.
console.log('RequestId-->' + result.InterfaceResult.RequestId);
// Obtain other parameters.
console.log('Content-->' + result.InterfaceResult.Content.toString());
}else{
// Obtain Code and Message.
console.log('Code-->' + result.CommonMsg.Code);
console.log('Message-->' + result.CommonMsg.Message);
}); What is your overall rating for this page?
