Deleting an Object Version (SDK for Node.js)
Function
You can call ObsClient.deleteObject to delete an object version specified by the VersionId parameter. For details about the API definition, see Deleting an Object (SDK for Node.js).
You can also call ObsClient.deleteObjects to delete multiple object versions at a time by passing all of their VersionId values. For details about the API definition, see Batch Deleting Objects (SDK for Node.js).
Code Examples: Deleting an Object Version
This example deletes version G001117FCE89978B0000401205D5DC9A of object example/objectname from bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint of the region where the bucket is located. server: "https://your-endpoint" }); async function deleteObject() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object (example/objectname in this example) to delete. Key: 'example/objectname', // Specify the ID of the object version. VersionId: 'G001117FCE89978B0000401205D5DC9A' }; // Delete a version of an object. const result = await obsClient.deleteObject(params); if (result.CommonMsg.Status <= 300) { console.log("Delete object(%s) under the bucket(%s) successful!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; deleteObject(); |
Code Examples: Deleting Object Versions
This example deletes objects objectname1, objectname2, and objectname3 from bucket examplebucket in a batch.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint of the region where the bucket is located. server: "https://your-endpoint" }); async function deleteObjects() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object list to delete. Objects: [ { Key: 'objectname1', VersionId: "version1" }, { Key: 'objectname2', VersionId: "version2" }, { Key: 'objectname3', VersionId: "version3" } ] }; // Delete the objects in a batch. const result = await obsClient.deleteObjects(params); if (result.CommonMsg.Status <= 300) { console.log("Delete objects under the bucket(%s) successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); // Return details about which objects were deleted. console.log('Deleteds:'); for (let i = 0; i < result.InterfaceResult.Deleteds.length; i++) { const deleted = result.InterfaceResult.Deleteds[i]; console.log("Deleted[%d]-Key:%s, VersionId:%s", i, deleted.Key, deleted.VersionId); }; // Return details about which objects were not deleted. console.log('Errors:'); for (let i = 0; i < result.InterfaceResult.Errors.length; i++) { const err = result.InterfaceResult.Errors[i]; console.log("Errors[%d]-Key:%s, Code:%s", i, err.Key, err.Code); }; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; deleteObjects(); |
