Deleting a Bucket (SDK for Node.js)
Function
This API deletes an empty bucket. You can delete buckets you no longer use to free up the quota of buckets. The name of a deleted bucket can be reused for another bucket at least 30 minutes after the deletion.
Restrictions
- Only empty buckets can be deleted. An empty bucket means that:
- The bucket does not contain any objects (including historical versions and delete markers).
- The bucket does not contain any fragments, which means that there are no multipart uploads that have not been completed in the bucket.
- Bucket deletion is a non-idempotence operation and will fail if the to-be-deleted bucket does not exist.
- To delete a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucket in IAM or DeleteBucket in a bucket policy).
Method
ObsClient.deleteBucket(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Responses
Type |
Description |
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 3. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Code Examples
You can call ObsClient.deleteBucket to delete a bucket. This example deletes bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint of the region where the bucket is located. server: "https://your-endpoint" }); async function deleteBucket() { try { const params = { // Specify the bucket name. Bucket: "examplebucket" }; // Delete a bucket. const result = await obsClient.deleteBucket(params); if (result.CommonMsg.Status <= 300) { console.log("Delete bucket(%s) successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; deleteBucket(); |
