Listing Buckets (SDK for Node.js)
Function
OBS buckets are containers for storing objects you upload to OBS. This API returns a list of all buckets that meet the specified conditions in all regions of the current account. Returned buckets are listed in alphabetical order by bucket name.
Restrictions
- To list buckets, you must have the obs:bucket:ListAllMyBuckets permission.
Method
ObsClient.listBuckets(params)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
QueryLocation | boolean | No | Explanation: Whether to query the bucket location Restrictions: None Value range:
Default value: false |
Constant | Description |
OBJECT | An object bucket |
POSIX | A parallel file system (POSIX) |
Responses
Type | Description |
NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 4. |
Parameter | Type | Description |
CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5. | |
InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 6. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). |
Code | string | Explanation: Error code returned by the OBS server. |
Message | string | Explanation: Error description returned by the OBS server. |
HostId | string | Explanation: Request server ID returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server. |
Id2 | string | Explanation: Request ID2 returned by the OBS server. |
Indicator | string | Explanation: Error code details returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
Owner | Explanation: Bucket owner Value range: See Table 7. | |
Buckets | Bucket[] | Explanation: Bucket information list Value range: See Table 8. |
ID | string | Yes if used as a request parameter | Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK). Default value: None |
DisplayName | string | No | Explanation: Account name of the owner Default value: None |
BucketName | string | Explanation: Bucket name. Restrictions:
CreationDate | string | Explanation: When the bucket was created. Default value: None |
Location | string | Explanation: Where a bucket is located. |
Code Examples
You can call ObsClient.listBuckets to list buckets. This example lists all buckets.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint of the region where the bucket is located. server: "https://your-endpoint" }); async function listBuckets() { try { const params = { // Specify whether to query the bucket location in the listing. The default value is false. true is used in this example. QueryLocation: true, // Specify a bucket type (object buckets in this example). If this parameter is not specified, object buckets and parallel file systems are listed by default. BucketType: "OBJECT", }; // List buckets. const result = await obsClient.listBuckets(params); if (result.CommonMsg.Status <= 300) { console.log("List buckets successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log('Owner:'); console.log('ID: %s', result.InterfaceResult.Owner.ID); console.log('Name: %s', result.InterfaceResult.Owner.Name); console.log('Buckets:'); for (let i = 0; i < result.InterfaceResult.Buckets.length; i++) { const val = result.InterfaceResult.Buckets[i]; console.log("Bucket[%d]-Name:%s,CreationDate:%s,Location: %s", i, val.BucketName, val.CreationDate, val.Location); }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; listBuckets(); |
