Help Center/ Object Storage Service/ Node.js SDK Developer Guide (Ally Region)/ Getting Started (SDK for Node.js)/ Creating a Bucket (SDK for Node.js)
Updated on 2026-01-16 GMT+08:00
A bucket is a global namespace of OBS and is a data container. It functions as a root directory of a file system and can store objects. The following code shows how to create a bucket:
- Bucket names are globally unique. Ensure that the bucket you create is named differently from any other bucket.
- A bucket name must comply with the following rules:
- Contains 3 to 63 characters, chosen from lowercase letters, digits, hyphens (-), and periods (.), and starts with a digit or letter.
- Cannot be an IP address.
- Cannot start or end with a hyphen (-) or period (.).
- Cannot contain two consecutive periods (..), for example, my..bucket.
- Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
- If you create buckets of the same name, no error will be reported and the bucket properties comply with those set in the first creation request.
- For more information, see Creating a Bucket (SDK for Node.js).
Parent topic: Getting Started (SDK for Node.js)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
