Downloading an SDK (SDK for Node.js)
Download
- Latest version of OBS Node.js SDK: Download
Compatibility
- Recommended versions: Node 0.12.x, Node4.x, Node6.x, Node8.x, or Node10.x
- Interface changes: The following table describes the interfaces not completely compatible with earlier versions 2.1.x:
Interface
ObsClient.listBuckets
In the response, the data type of InterfaceResult.Buckets was changed to Array. InterfaceResult.Buckets.Bucket was deleted.
ObsClient.setBucketAcl
In the request, the data type of Grants was changed to Array. Grants.Grant was deleted.
ObsClient.getBucketAcl
In the response, the data type of InterfaceResult.Grants was changed to Array. InterfaceResult.Grants.Grant was deleted.
ObsClient.setObjectAcl
ObsClient.getObjectAcl
ObsClient.setBucketLogging
In the request, the data type of LoggingEnabled.TargetGrants was changed to Array. LoggingEnabled.TargetGrants.Grant was deleted.
ObsClient.getBucketLogging
In the response, the data type of InterfaceResult.LoggingEnabled.TargetGrants was changed to Array. InterfaceResult.LoggingEnabled.TargetGrants.Grant was deleted.
ObsClient.setBucketWebsite
In the request, the data type of RoutingRules was changed to Array. RoutingRules.RoutingRule was deleted.
ObsClient.getBucketWebsite
In the response, the data type of InterfaceResult.RoutingRules was changed to Array. InterfaceResult.RoutingRules.RoutingRule was deleted.
ObsClient.setBucketCors
In the request, CorsRule was renamed as CorsRules.
ObsClient.getBucketCors
In the response, InterfaceResult.CorsRule was renamed as InterfaceResult.CorsRules.
ObsClient.setBucketTagging
In the request, the data type of TagSet was changed to Array. TagSet.Tag was deleted.
ObsClient.getBucketTagging
In the response, the data type of InterfaceResult.TagSet was changed to Array. InterfaceResult.TagSet.Tag was deleted.
