Help Center/ Object Storage Service/ BrowserJS SDK Developer Guide (Ally Region)/ Lifecycle Management/ Viewing Lifecycle Rules
Updated on 2026-01-16 GMT+08:00
You can call ObsClient.getBucketLifecycle to view lifecycle rules of a bucket.
This example views the lifecycle configuration of bucket bucketname.
The example code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' ' }); obsClient.getBucketLifecycle({ Bucket: 'bucketname' }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ for(var i=0;i<result.InterfaceResult.Rules.length;i++){ console.log('Rule[' + i + ']:'); console.log('ID-->' + result.InterfaceResult.Rules[i]['ID']); console.log('Prefix-->' + result.InterfaceResult.Rules[i]['Prefix']); console.log('Status-->' + result.InterfaceResult.Rules[i]['Status']); for(var j=0;j<result.InterfaceResult.Rules[i]['Transitions'].length;j++){ console.log('Transition[' + j + ']:'); console.log('Transition[StorageClass]-->' + result.InterfaceResult.Rules[i]['Transitions'][j]['StorageClass']); console.log('Transition[Date]-->' + result.InterfaceResult.Rules[i]['Transitions'][j]['Date']); console.log('Transition[Days]-->' + result.InterfaceResult.Rules[i]['Transitions'][j]['Days']); } console.log('Expiration[Date]-->' + result.InterfaceResult.Rules[i]['Expiration']['Date']); console.log('Expiration[Days]-->' + result.InterfaceResult.Rules[i]['Expiration']['Days']); for(var k=0;k<result.InterfaceResult.Rules[i]['NoncurrentVersionTransitions'].length;k++){ console.log('NoncurrentVersionTransition[' + k + ']:'); console.log('NoncurrentVersionTransition[StorageClass]-->' + result.InterfaceResult.Rules[i]['NoncurrentVersionTransitions'][k]['StorageClass']); console.log('NoncurrentVersionTransition[NoncurrentDays]-->' + result.InterfaceResult.Rules[i]['NoncurrentVersionTransitions'][k]['NoncurrentDays']); } console.log('NoncurrentVersionExpiration[NoncurrentDays]-->' + result.InterfaceResult.Rules[i]['NoncurrentVersionExpiration']['NoncurrentDays']); } } } });
Parent topic: Lifecycle Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
