Help Center/ Object Storage Service/ BrowserJS SDK Developer Guide (Ally Region)/ Object Upload/ Obtaining Upload Progresses
Updated on 2026-01-16 GMT+08:00
You can set the callback function to obtain upload progress.
This example uploads a file to bucket bucketname as object objectname and uses ProgressCallback to monitor the upload progress.
The example code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); var callback = function(transferredAmount, totalAmount, totalSeconds){ // Obtain the average upload rate (KB/s). console.log(transferredAmount * 1.0 / totalSeconds / 1024); // Obtain the upload progress in percentage. console.log(transferredAmount * 100.0 / totalAmount); }; obsClient.putObject({ Bucket: 'bucketname', Key: 'objectname', SourceFile: document.getElementById('input-file').files[0], ProgressCallback: callback }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- You can query the upload progress when uploading an object in text-based, file-based, multipart, appendable, or resumable mode.
Parent topic: Object Upload
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
