Management Bucket Policies
Besides bucket ACLs, bucket owners can use bucket policies to centrally control access to buckets and objects in buckets.
Setting a Bucket Policy
You can call ObsClient.setBucketPolicy to set bucket policies. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); // Bucket name const bucketName = 'bucketname'; // Bucket policy const policy = "{\"Statement\":[{\"Principal\":\"*\",\"Effect\":\"Allow\",\"Action\":\"ListBucket\",\"Resource\":\""+bucketName+"\"}]}"; //Set a bucket policy. obsClient.setBucketPolicy({ Bucket: bucketName, Policy: policy }, function(err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
For details about the format (JSON character string) of bucket policies, see the Object Storage Service API Reference.
Obtaining a Bucket Policy
You can call ObsClient.getBucketPolicy to obtain bucket policies. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); // Obtain the bucket policy. obsClient.getBucketPolicy({ Bucket: 'bucketname', }, function(err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ console.log('Policy-->' + result.InterfaceResult.Policy); } } });
Deleting a Bucket Policy
You can call ObsClient.deleteBucketPolicy to delete a bucket policy. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); // Delete a bucket policy. obsClient.deleteBucketPolicy({ Bucket: 'bucketname' }, function(err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
