Creating an Instance of ObsClient
ObsClient functions as the BrowserJS client for accessing OBS. It offers callers a series of APIs for interaction with OBS. These APIs are used for managing and operating resources, such as buckets and objects, stored in OBS. To use OBS BrowserJS SDK to send a request to OBS, you need to initialize an instance of ObsClient and modify parameters related to initial configurations of the instance based on actual needs.
Direction Creation
- Sample code for creating an ObsClient instance using a permanent access key (AK/SK):
// AMD is not introduced. Use the constructor to create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); // Use the instance to access OBS.
- Sample code for creating an ObsClient instance using temporary credentials (AK/SK and security token):
// AMD is not introduced. Use the constructor to create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID, SecretAccessKey, and SecurityToken. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, security_token: process.env.SecurityToken, server: 'https://your-endpoint' }); // Use the instance to access OBS.
Creation According to AMD
// AMD is introduced. Use the injected constructor to create an instance of ObsClient. var obsClient; define(['ObsClient'], function(ObsClient){ obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, server: 'https://your-endpoint' }); // Use the instance to access OBS. });
// AMD is introduced. Use the injected constructor to create an instance of ObsClient. var obsClient; define(['ObsClient'], function(ObsClient){ obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID, SecretAccessKey, and SecurityToken. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, security_token: process.env.SecurityToken, server: 'https://your-endpoint' }); // Use the instance to access OBS. });
